Trimble R6 + GPScorrect for ArcPad
1078
07-07-2011 01:02 AM
PawelFedczak
Hello.
I'd like to use Trimble R6 receiver to collect data in ArcPad 7.1 with GPScorrect extension in order to post-process them later in GPS Analyst. Is it possible? Is there any way to configure this connection in ArcPad or another software? I could connect my receiver when I choose NMEA protocol in ArcPad but when I choose GPScorrect protocol, receiver can't be connected.
Best regards,
Pawel.
Tags (3)
D3EGPS
Hi pawel,
Unfortunately the Trimble gpscorrect extension is only available for mgis receivers and not with survey ones.
The only solution in your case is to configure a real time correction with a configurator software and set a real time output correction and output nmea option.
Set in arcpad a standard nmea protocol.
Gps correct will not connect to survey receivers, and even, Trimble gps analyst won't correct any hypothetic files collected with a survey receiver...(see trimble website for more informations)
Hope that helps
PawelFedczak
Thank's for your reply.
I've thought the same way and I wanted to be sure about this.
Best regards,
Pawel.
