Trimble, Field Inspector  and Shapefiles
968
10-15-2013 08:10 AM
EdwardTanas
Is it possible to have a database that has data imported (Spatial location (x, y, Z) and attributes) from a Trimble unit in a database created via the Field Inspector software
export a shapefile that I can then import into a Geodatabase via ArcCatalog...
If so workflow to do so or best way to do so is..???
thank you
Tags (3)
trimble_supporttrimble_support
Yes it is possible, once an inspection has been returned to the Field Inspector desktop, to export inspection and coordinate data to a shape file using the FI "export to shape file" function. This shape file can then be imported into ArcMap for display or update. The export to shape file approach can be a good option for example, if you have purchased a device with greater accuracy and would like to update your existing GIS data. In other cases a direct update to a geodatabase might make sense.
