Synchronize edits between ArcPad and Enterprise Geodatabase
3783
06-30-2014 11:54 AM
by Anonymous User
Not applicable
Original User: hanidraidi
I am trying to synchronize edits done with ArcPad in the field with the enterprise geodatabase, using the following steps:
1-Preparing the layers in ArcMap (Using Enterprise Geodatabase).
2-Checking Out the layers to AXF layers to be used in ArcPad.
3-Publishing the map document as a service using ArcGIS Server and enabling feature access capability.
4-Creating a layer from the published feature service.
5-Using �??Add feature Service URL to AXF�?� with the created layer and the .AXF layer.
6-Opening the layer in ArcPad.
7-Using the Synchronize Data with ArcGIS Server tool.
This procedure is also documented in this blog: http://blogs.esri.com/esri/arcgis/2013/09/22/feature-service-sync-in-arcpad-10-2/
An error that prevents synchronizing appears (in the screenshots below)
What might be the problem here?
1- Checking out data to ArcPad using Get data for ArcPad tool.
[ATTACH=CONFIG]34991[/ATTACH]
2- Publishing the map as a service, and enabling feature access capability.
[ATTACH=CONFIG]34992[/ATTACH]
3- Creating a layer from the feature service.
[ATTACH=CONFIG]34993[/ATTACH]
4- Using Add feature Service URL to AXF tool (ArcPad toolbox)
[ATTACH=CONFIG]34994[/ATTACH]
5- Opening the AXF in ArcPad, making some edits, and synchronizing data with ArcGIS Server; At this step the error appears
[ATTACH=CONFIG]34995[/ATTACH]
Regards,
Hani
Tags (3)
