Slow ArcPad using Motorola MC67
3671
03-27-2016 02:33 PM
DavidBierman
I have been using ArcPad 10.2.2 with a Motorola MC55 which has Windows CE.  The speed is fairly fast.  I then switched to Motorola MC67 which should be faster and better but it is significantly slower.  Does anyone know why the MC67 is slower than the MC55?
Tags (1)
AdrianWelsh
MVP Honored Contributor
Hi David,
That is odd. A few questions. Are you using the same data and same project as the previous handheld? Does the newer handheld run the same OS? Do other similar software programs run similar to each other?
Is it possible that, if you are using the same project, that the project may have gotten corrupted during a transfer? What I am wondering is if you could re-create your project for the new handheld if that would help performance.
