Showing the attribute table of a layer in the ArcPad,
5834
11-25-2013 07:38 AM
JamalNUMAN
Legendary Contributor
I couldn�??t figure out how to show the attribute table of a particular layer in the ArcPad.
[ATTACH=CONFIG]29321[/ATTACH], [ATTACH=CONFIG]29322[/ATTACH]
Thank you
Best
Jamal
Jamal Numan
Tags (4)
HannahFerrier
Attribute tables are not able to be displayed in ArcPad in the field.
If you need to review your data before checking it back into your geodatabase, you can open your AXF in ArcPad Studio. Right-click on the layer you want to view and select 'Show Data' from the menu. This will open your attribute table in ArcPad Studio.
This is a great resource as the top of the dialog can be used to execute SQL queries. This can help you to identify any errors in your data eg. misspellings, junk data, null values.
[ATTACH=CONFIG]30266[/ATTACH]
Hannah 🙂
by Anonymous User
Not applicable
Original User: [email protected]
Hannah 🙂
Many thanks Hannah for the help,
What if the data is available in shape file format? Is there a way to view its attribute table in ArcPad Studio?
[ATTACH=CONFIG]30291[/ATTACH], [ATTACH=CONFIG]30292[/ATTACH], [ATTACH=CONFIG]30293[/ATTACH]
