Setting the coordinate system of the *.apm file,
4228
09-19-2013 01:35 AM
JamalNUMAN
Legendary Contributor
I couldn???t figure out how the coordinate system of the *.apm can be set or switched.
[ATTACH=CONFIG]27575[/ATTACH], [ATTACH=CONFIG]27576[/ATTACH]
Thank you
Best
Jamal
Jamal Numan
Tags (4)
BrettBlack
You do not set the coordinate system of the .APM file. The coordinate system is related to the feature classes in the .AXF. So when you use the ArcPad Data Manager tool, the coordinate system of your feature classes is maintained through the check-out process and utilized in ArcPad.
BrettBlack
by Anonymous User
Not applicable
Original User: jaredpilbeam
If I can add to that: You choose your coordinate system when you create your feature class in ArcMap, before you even use the ArcPad data manager.
Hope this helps.
JamalNUMAN
Hope this helps.
Many thanks Brett and jared for the help.
[ATTACH=CONFIG]27600[/ATTACH], [ATTACH=CONFIG]27598[/ATTACH], [ATTACH=CONFIG]27599[/ATTACH]
I thought that the coordinate system can still be set from the ArcPad.
Best
Jamal
Jamal Numan
