SD Card Issue?
762
12-16-2010 11:03 AM
ShaunBresnahan
I am running ArcPad 10 on a Trimble Nomad 800G, I like to put my ArcPad maps on a SD card. I have noticed that when I have a map open in ArcPad if I hit the power button to put the unit in standby, when I turn it on more times then not ArcPad frezes.  I can run Excel or Word no problem, and these documents are on the SD card. If  I put the ArcPad project in Main Memeory this isn't an issue.
I remeber my Recon had the same issue and I had to edit the registry to fix this issue.
Has anyone else run into thihs problem?
Tags (3)
