Recordset Update no longer working
3645
04-29-2014 10:36 AM
JonDewalt
Hello
I have the following procedure that i call from the Layers onfeatureadded event. This code used to work perfectly but now with ArcPad 10.2 it does not work.  I am looking for a new way.  I use the RecordSet object in numerous places on dozens of forms.  I have been looking into using SQL with Datasource.execute but not sure how i would update the current record.
Sub Record_Created
Dim pRS
Set pRS = Layer.Records
pRS.Bookmark = ThisEvent.Bookmark
dim i, strFieldName
for i = 1 to pRS.fields.count
  strFieldName = UCase(pRS.Fields(i).Name)
  Select Case strFieldName
   Case UCase(Field_RecordID)
    pRS.Fields(Field_RecordID).Value = CurrentRecordID
   Case UCase(Field_Creator)
    pRS.Fields(Field_Creator).Value =  application.userproperties("SRDUserName")
   Case UCase(Field_CreationDate)
    pRS.Fields(Field_CreationDate).Value =  now()
   End Select
next
  pRS.Update
End Sub
Tags (3)
AndyOpenshaw
This has happened to me also. Update method for recordset no longer works in 10.2. Does anyone have any information on this?
