RecordSet Export to csv
2478
06-23-2016 12:24 PM
IngridHogle
I am trying to use the Recordset Export method to export a shapefile's .dbf to a .csv file. The .csv file gets created, but then ArcPad crashes...and the .csv file is empty. Here is my code, which I call OnSetActive of a page. If I comment out the pRS.Export line, no .csv file is created and ArcPad does not crash. But I need a .csv file with the data as my output.
Can anyone troubleshoot this or perhaps share a snippet of code where they were able to successfully use the Recordset's Export method, so I can see what I am doing wrong?
Sub CreateCSV()
    '++ create the recordset object
    Dim pRS
    Set pRS = Application.CreateAppObject("RecordSet")
    '++ create a shapefile and add a field
    Call pRS.Create ("Y:\Prep\ArcPadPrep\DATACHECKS\Testing.shp", apShapePoint)
    Call pRS.Fields.Append ("LfNodes", apFieldNumeric)
    '++ Open new shapefile, add a feature, set the value of the field LfNode to 1, update and close
    pRS.Open "Y:\Prep\ArcPadPrep\DATACHECKS\Testing.shp",2
    pRS.AddNew
    pRS.Fields("LfNodes").Value = 1
    pRS.Update
    pRS.Close
    '++ export Testing.dbf to Testing.csv
    pRS.Export "Y:\Prep\ArcPadPrep\DATACHECKS\Testing.csv",-1
    '++ clean up
    Set pRS = Nothing
End Sub
RebeccaStrauch__GISP
I don't know if this will help, but maybe try putting ( )  around the args for th pRS.Open and pRS.Export  ??  just a quick observations ....nothing tested.
