Quick Project Template
2134
05-16-2012 10:49 AM
JimJolley
I created 4 Quick Projects templates successfully.  However, when a Quick Project is created, the user does not have the choice to "keep layers from current map" using any of the 4 templates.  The default template gives the user the choice.  How can the 4 new templates be made to have the choice to "keep layers from current map".
Tags (3)
GarethWalters
Hi Jim,
My thoughts are that the templates were thought of as self contained projects, whereas the QuickProject allows for a set of customisable data to be created in the field. However, we will raise an enhancement request so it is on the list, but its a long list 🙂
Thanks for you thoughts.
Cheers,
Gareth
emelinerenz1
Was this functionality ever implemented?
We have the need to distribute a template for gathering data to our clients, who would all have different base layers but would have one common set of feature classes/shapefiles to edit. We need to be able to open a Quick Project template with the editable layers ON TOP of a "basemap" map. Why have this option if it is not able to be activated for any quick template?
Please explain how I might be able to enable this option when using a quick template.
emeline
