projection and datum problems with ArcPad 7.1
1452
08-11-2011 06:53 AM
JosueDiaz
Hi, I have the following problem with ArcPad 7.1:
/My documents/PrjData.dll
not found
Projection and datum
transforms may not operate correctly
I understand that the projection and datum are not found in my document, but to do in this situation. I hope your help, thanks in advance and greetings from the beautiful Quisqueya.
Josue Diaz
Consultant and specialist in Geographic Information Systems (GIS)
Tags (3)
TimHopper
Josue,
This is a known issue in ArcPad 7.1 which is documented in the following KB article:
Error: PrjData.dll not found. Projection and datum transforms may not operate correctly.
http://support.esri.com/en/knowledgebase/techarticles/detail/34210
The workarounds would be as follows:
1. Modify the System Files Path in the ArcPad Options > Paths dialog box to display C:\Program Files\ArcPad 7.1\System (Tools > Options > Paths > System Files Path)
or..
2. Delete the ArcPadPrefs.apx in My Documents before opening ArcPad 7.1 for the first time. (Or rename the current ArcPadPrefs.apx file to ArcPadPrefs_old.apx).
Hope this helps!
JosueDiaz
Thanks for the help, served me well.
Josue Diaz
