Populate 2 Attributes based on one Value
2330
06-24-2010 03:44 PM
AndrewHansford
Hi All,
I am working on a project in ArcPad 8 SP3.
I have a Shapefile with to fields
  1. UserNumber (Long Integer)
  2. UserText3 (Text Field)
Below is my Code that i have created to autogenerate a Unique ID and my Text_box that it relates to will store that value that is returned to UserNumber. How would I go about adding that value directly to the Attribute table for UserText3?
Sub InitialiseGPSID
'Do any form initialization in this sub
 Dim objEFPageOneControls, objEditForm
 Set objEditForm = ThisEvent.Object
 Set objEFPageOneControls = objEditForm.Pages("PAGE1").Controls
 'Initialization for form in any mode
 'Disable the GPS ID edit box
  objEFPageOneControls("txt_GPSID").Enabled = False
  'Initialization for form when adding new records
  If objEditForm.Mode = 3 Then ' Mode 3 is used when creating a new feature.
    'Get the Fence Points layer's recordset (to pass into the ReturnNextID function)
    Dim objUniqueID
    Set objUniqueID = Layer.Records
 if ReturnNextID (objUniqueID, "USERNUMBER") = 1 then
    'Update the Tree ID
     objEFPageOneControls("txt_GPSID").Value = ReturnNextID (objUniqueID, "USERNUMBER") + 10000
 else
 end if
  End If
  'Free objects
  Set objEFPageOneControls = Nothing
  Set objEditForm = Nothing
  Set objUniqueID = Nothing
End Sub
'Also write the function ReturnNextID that is called by InitializeForm.
Function ReturnNextID (objRS, strFieldName)
  Dim intMax
  'Get the first record
  objRS.MoveFirst
  'Initialize the max value to the first record
  intMax = CInt(objRS.Fields(strFieldName).Value)
  'Loop through the records, updating the max value if necessary
  Dim intCurrVal
  While Not objRS.EOF
    intCurrVal = CInt(objRS.Fields(strFieldName).Value)
    If (intCurrVal > intMax) Then
      intMax = intCurrVal
    End If
    objRS.MoveNext
  Wend
  ReturnNextID = intMax + 1
End Function
Tags (3)
AndrewHansford
I figured out a quick and easy solution:
Sub InitialiseGPSID
    Dim objUniqueID
    'Update the Tree ID
 objEFPageOneControls("txt_AssetID").Value = ReturnNextID (objUniqueID, "USERNUMBER") + 10000
 else
 end if
  End If
  'Free objects
End Sub
  Dim intMax
  objRS.MoveFirst
  Dim intCurrVal
  While Not objRS.EOF
      intMax = intCurrVal
    End If
    objRS.MoveNext
  Wend
End Function
The text in the yellow links to a invisible text box in the form then saves the value to the field in the Shapefile.
not a clear work around but does for now.
Cheers
