Loop through Controls
1196
02-24-2012 06:03 AM
MatthewMurray1
I was just wondering if there is a way to loop through all controls on a form without knowing the control name. I would just like to use the index.
thanks
Tags (3)
GarethWalters
You can use the ThisEvent object. Check out the ArcPad studio help on this there is an example that you could adjust for your needs. Let me know if you need anymore info.
Cheers,
Gareth
RobChouinard
Yes you can. Here is a snippet of code I use:
Dim objPg, Cntl, objFrm
set objFrm = ThisEvent.object
set objPg = objFrm.pages("page1")
For each Ctrl in objPg.Controls
