Image sharpness in 10.0 build 33
995
02-18-2012 08:39 AM
JohnZimmerman
In my prior version of ArcPad, v 7, I had to download and install a fix to be able to view images in full sharp resolution.  Is the same necessary in 10?  I notice that 10 is not displaying my sid image quite as sharp as ArcMap does.
Tags (3)
HannahFerrier
Hi John,
To answer your question, no - there is no fix needed for ArcPad regarding map display.
If you are noticing a difference in display quality between your desktop and mobile device - please be aware of the hardware specifications of each platform. It may be that the screen on your mobile device is not able to perform as well as your PC monitor.
If you are talking about running ArcPad and ArcMap side-by-side on your desktop PC - could you please provide screenshots?
Hannah Ferrier
