getting data from arcpad into arcmap 10.1
2829
09-19-2013 12:12 PM
DavidO_Donnell1
I was familiar with ArcMap10's method of using ArcPad data manager to check in edits from a GPS unit (Trimble Juno SB). the ArcPad data manager tool doesn't seem to be present in 10.1. How can I check in my edits to a layer?
Tags (3)
ValentinWittich
I can just describe the way I do it. As I have to update many projects on at least 4 or 5 devices, I'm using the way that I take the SDcard from the device and sync it with the my ArcPad folder on the PC (by using Total Commander). Therefore you just have to make sure that ArcPad saves the data on the SD card.
Hope that helps, though its not the suggested method by ESRI.
Regards
Valentin
HannahFerrier
You will need to uninstall and reinstall ArcPad to install the Data Manager Toolbar if you have installed a newer version of ArcMap.
The ArcPad Data Manager Toolbar and other ArcPad Toolbar Tools will have installed into your ArcMap 10 folder.
An uninstall/reinstall will place them in the new ArcMap 10.1 folder.
A couple of other things to try if you still cannot find the ArcPad Data Manager Toolbar in ArcMap 10.1:
- Make sure ArcPad and ArcMap are both installed on the same machine (the toolbar is included in the ArcPad installation).
- Make sure that you have enabled the ArcPad Data Manager Extension by selecting Extensions from the Customize menu and check the box next to ArcPad Data Manager.
- Right-click on any area in the toolbar in ArcMap and check ArcPad Data Manager to add the toolbar to your map.
Hope this helps,
Hannah 🙂
