Get Data for ArcPad Disabled
2265
01-04-2013 10:43 AM
MeganCatalina
Hello.  I have been using Trimble GPS Analyst on my computer for a while now.  I was trying to make a new map for out in the field and my Get Data for ArcPad is Disabled.  I have the Extension on in both ArcCatalog and ArcMap.  The geodb is enabled with spatial reference.  When I bring in a feature class the GNSS showes up in the Table of Context but the Get Data for ArcPad does NOT active!  I have no idea what is going on.  Any ideas?
Tags (3)
JuanLuera
Hola,
I would suggest making sure that both ArcPad and GPS Analyst extension are activated within ArcMap. Then I would suggest using the GPS Analyst Toolbar within ArcMap to check data out your data, then within the toolbar you will be able to use the GNSS option within it to check the data back in. One last item I would also suggest, is to verify the personal geodatabase is GPS Enabled within ArcCatalog within the properties of the personal geodatabase. Gracias!
