Field.Shape = Point
1105
12-10-2012 06:50 AM
BenjaminCumberland
I had this code working in ArcPad 8.  When I tried to bring it over to ArcPad 10, I keep getting an error.  The error is "Error Source Unavailable", "Error Description: Unavailable".
Basically, the user clicks on the map, a form pops up, user enters information, then information is saved to that point.  Point is then created and placed on map.  Here's the code and the error comes up when it hits "pField.Shape = pPt":
Sub SaveFieldData()
   Dim pControls, pCtl, pPt
      Dim pLayer, pRS, pFields
      Dim sDate, sTime, sTeam, sLocation, sLat, sLon, sMeasurement, sUnits, sMeasuringLocal, sMeasuring, sSymbolId, sComments
      Set pControls = Application.Forms("frmFieldData").Pages("PAGE1").Controls
      Set pLayer = Map.Layers("Field Data")
      pLayer.Editable = True
      Set pRS = pLayer.Records
      Set pFields = pRS.Fields
      Dim editRecord, sMeasId, sOrigDataId, sDataId, sLocalEdit, sSaveEditFlag
      editRecord = Application.UserProperties("EditRecord")
      Set pCtl = pControls("edtDate")
      sDate = pCtl.Value
      Set pCtl = pControls("edtTime")
      sTime = pCtl.Value
      Set pCtl = pControls("cboTeam")
      sTeam = pCtl.Value
      Set pCtl = pControls("edtLocation")
      sLocation = pCtl.Value
      Set pCtl = pControls("edtLat")
      sLat = pCtl.Value
      Set pCtl = pControls("edtLon")
      sLon = CDbl(pCtl.Value)
      Set pCtl = pControls("edtMeasured")
      sMeasurement = pCtl.Value
      Set pCtl = pControls("cboUnits")
      sUnits = pCtl.Value
      Application.UserProperties("LastUnits") = sUnits
      Set pCtl = pControls("cboMeasurementType")
      sMeasuring = pCtl.Text
      sMeasuringLocal = pCtl.Value
      Application.UserProperties("LastMeasurementType") = sMeasuringLocal
      Set pCtl = pControls("cboPlotCategory")
      sSymbolId = pCtl.Value
      Application.UserProperties("LastPlotCategory") = sSymbolId
      Set pCtl = pControls("edtComments")
      sComments = pCtl.Value
      If editRecord > 0 Then
            pRS.Bookmark = editRecord
      Else
     pRS.AddNew
      End If
      ' project the point    into map coordinates
      Dim dblX, dblY
      dblX = CDbl(sLon)
      dblY = CDbl(sLat)
      Call ProjectLLToMap (dblX, dblY)
      ' add to the recordset
      Set pPt = Application.CreateAppObject ("Point")
      pPt.X = dblX
      pPt.Y = dblY
            sMeasId = pFields("meas_id").Value
            sDataId = pFields("data_id").Value
            sLocalEdit = "E"
      Else
            sMeasId = -1
            sDataId = Application.UserProperties("MinDataId")
            sLocalEdit = "C"
      End If
      If sDataId < 0 Then
            Application.UserProperties("MinDataId") = Application.UserProperties("MinDataId") - 1
      End If
      pFields("SITE_NAME").Value = Application.UserProperties("Sitename")
      pFields("DATETIME").Value = CDate(sDate & " " & sTime)
      pFields("TEAM").Value = sTeam
      pFields("TIMESTAMP").Value = CDate(Now)
      pFields("AUTHOR").Value = sTeam
      pFields("LOCATION").Value = sLocation
      pFields("LONGITUDE").Value = sLon
      pFields("LATITUDE").Value = sLat
      pFields("CATEGORY").Value = Application.UserProperties("Category")
      pFields("UNITS").Value = sUnits
      pFields("MEASURING").Value = sMeasuring
      pFields("COMMENTS").Value = sComments
      pFields("DATA_ID").Value = sDataId
      pFields("SYMBOL_ID").Value = sSymbolId
      pFields("LABEL").Value = sMeasurement & "," & sUnits & "," & sMeasuringLocal
      pFields("MEAS_ID").Value = sMeasId
      pFields("MEASUREMNT").Value = sMeasurement
      pFields("EDIT_SYM").Value = sSymbolId & sSaveEditFlag
      Set pFields.Shape = pPt
      pRS.Update
Sub ProjectMapToLL (dblX, dblY)
      'Create a Point object (which inherits the map's coordsys)
      Dim pPt
      'Assign the X and Y values to the point object
      pPt.X = dblX
      pPt.Y = dblY
         'Create a NAD1983 Lat/Lon CoordSys object
      Dim pLatLonCS
      Set pLatLonCS = Application.CreateAppObject ("CoordSys")
      pLatLonCS.Import Application.UserProperties("DefaultPath") & "\Coordinate Systems\North American Datum 1983.prj"
      'Unproject the point to WGS 1984 Lat/Lon
      Dim pUnproj
      Set pUnproj = pLatLonCS.Project (pPt)
      dblX = pUnproj.X
      dblY = pUnproj.Y
      'Clean up
      Set pPt = Nothing
      Set pLatLonCS = Nothing
      Set pUnProj = Nothing
End Sub
Tags (3)
BenjaminCumberland
I finally figured it out.
Old Code:
pRS.AddNew
New Code:
pRS.AddNew pPt
BenjaminCumberland
Old Code:
pRS.AddNew
New Code:
pRS.AddNew pPt
