Failed to load layers in ArcPAD
1240
03-30-2011 01:35 AM
saifAlomari
i used to checkout data from PC to ArcPad with no problems at all, recently i did new checkout but non of them works in ArcPad, when checking out data i got message from ArcMap (successfuly for all selected layers), when open in ArcPad i recieve this message (Failed to Laod layers), the only opend layers are rasters.
Any idea??
my system environment is ,Windows xp professional SP3, ArcMap 9.3.1 (build 4000)
Trimple Juno ArcPad 8.0 SP1
Tags (3)
AdaYAO
Hi, I hava a same problem with ArcPad 10. Does anyone know the solution? Thanks.
JasonTipton
Usually, this happens to me on my desktop. From my experience, it is usually because I have the .axf open in ArcPad Studio at the same time that I try to open it in ArcMap. I have also seen this on checkout if you are using a template to check-out.  You need full access to the folder where that template resides.  The only other time that I have ever received this message is maybe when I had the .axf open in ArcPad Studio when I tried to sync with my device. It usually just won't work, but sometimes it works but with issues.
Basically, from my experience this usually happens b/c of permissions/locks on data.
AdaYAO
Hi, check if the locale setting of PC and the ArcPad are the same. I change the locale setting and it is OK now.
