Does arcpad have the function to enable the mapping of habitats by tracking around the area, say a patch of seagrass and saving the resulting track as a polygon?
3854
12-03-2015 07:27 AM
StevenDalton
We wish to map the area of seagrass in estuaries by navigating around the perimeter of the seagrass patches whilst arcpad software installed onto a field device, magellan explorist pro 10, maps these areas that will then be used to determine area of seagrass cover. Can this be done?
Your comments are appreciated
Steve
FreddieGibson
Honored Contributor
ArcPad is essentially designed to collect feature/attribute data in the field. You could collect the polygons using the GPS or you could digitize them with a pen on the screen.
Steps to create polygon features with a GPS
http://resources.arcgis.com/en/help/arcpad/10.2/app/#/Steps_to_create_polygon_features_with_a_GPS/00...
Creating a polygon feature using the Rectangle, Ellipse, Circle, or Freehand tool
http://resources.arcgis.com/en/help/arcpad/10.2/app/#/Creating_a_polygon_feature_using_the_Rectangle...
Creating a polygon using the Polygon tool and the pen
http://resources.arcgis.com/en/help/arcpad/10.2/app/#/Creating_a_polygon_using_the_Polygon_tool_and_...
DanPatterson_Retired
Rather than limit my response, you might be interested to the online link where you can find out more about the capabilities.   ArcPad - Mobile Data Collection & Field Mapping Software
FreddieGibson
Honored Contributor
StevenDalton
Thanks Freddie, the polygon with gps link application is what I am after, thanks for your direction
cheers
steve
FreddieGibson
Honored Contributor
You may also want to check this out.
ArcPad - And Introductio | Esri Video
http://video.esri.com/watch/2680/arcpad-_dash_-an-introduction
