DEM to ArcPad
3884
11-18-2014 08:43 AM
GreggHileman
DEM to ArcPad. I need guidance and instructionws for porting a Digital Elevation Model (DEM) [grid, 32-bit, floating pt] to ArcPad for display as a basemap. Thanks
Tags (3)
JuanLuera
HI Gregg,
Here is my suggestion on your post, with regards to using a DEM with ArcPad. If your DEM is one of the supported raster format, found in the link provided. You can then use the general ArcPad workflow for it, as you would to add a shapefile, axf, etc. directly into ArcPad.
Gracias, Gregg!
Supported raster data
http://resources.arcgis.com/en/help/arcpad/10.2/app/index.html#//00s10000001r000000
Juan
