Check out personal geodatabase to ArcPad
3450
06-14-2011 09:43 PM
CharlesHuxtable
Hello, I am trying to replicate the "Riverside" sample that comes with the ArcPad application. I ran it on my desktop and it has the functionality that I need for a project I'm working on. I am having problems though, in setting up a geodatabase with related tables, that can then be checked out to arcpad with associated MDB,AXF, Access database files, etc. I have worked out how to use the GetDataForArcpad tool to create a project for ArcPad, but when I do, I only get the ArcPad Map file,shapefiles, APL, DBF and VBS files. Does anyone know of a example that works through the process of creating a personal geodatabase with SQL references and AXF file creation, to checking it out to ArcPad?? I'm not really a programmer, but would dearly love some help.
Tags (3)
JuanLuera
With checking out your personal geodatabase from ArcMap for ArcPad. Are you using the Action, Check out for disconnect editing. With this option selected for the data, you will be able to have all the appropriate files created. Then when you open the .apm within ArcPad your related tables will reflect, once you capture a new feature.
