Cannot Check out related tables in File Geodatabase using ArcPad 10.0.3
1204
03-21-2012 09:54 AM
ChetHagen
I am trying to check out one feature class and three related tables using ArcMap 10.0.4 and ArcPad 10.0.3 in a Windows XP environment.  I have added the three tables, which are stored in the file geodatabase and have relationship classes, into the .mxd to no avail.  I have uninstalled and reinstalled ArcPad 10.0.3 four times and deleted all associate folders each time.  The check out process works when I select the feature class, but the tables have yet to be available for check out.  Any ideas?
Chet Hagen
Tags (3)
DeniseKing
Chet,
Are you able to check out the Riverside project in ArcPad\Samples folder? The Riverside geodatabase contains relationship classes and Help\Tutorials\Using Related Tables includes instructions of the complete workflow to perform check out project, edit related tables in ArcPad, and project check in back to geodatabase. The tutorial and sample data will help to determine if problem is specific to your data or, if also fails w/Riverside data, possible software configuration issue. If you still experience problems after working through Riverside sample and current ArcPad maintenance, please contact Esri Support and submit a support interaction so you can work with ArcPad specialist.
Cheers,
Denise
