Can't Check In ArcPad AXF file using Trimble Positions Desktop
7597
10
03-14-2013 11:02 AM
kg76
I'm testing Trimble Positions with a file geodatabase and I can't seem to check in my data. I'm using the Trimble Positions ArcPad extension to collect data on a Trimble GeoXT 6000 unit. Here's the error message I receive:
"Unhandled exception has occurred in a component in your application. If you click Continue, the application will ignore this error and attempt to continue. The process cannot access the file (and then it lists the file path of my .axf file) because it is being used by another process."
I can't figure out what other "process" would be using my .axf file. I always make sure to close ArcPad on my GPS unit after collecting data. I do not have ArcPad open on my computer. The only application I have running is ArcMap. I'm not using the ArcPad data manager toolbar, I'm using the Trimble Positions Desktop window to check in data. I manually copy and paste my check in and check out folders to and from the GPS unit. Also, I can't override it manually and "continue" like the error message claims.
I've followed the workflows in the Administrator/User Guides for Trimble Positions when setting up my map document and GNSS enabling my geodatabase, etc.
Any ideas?
Kerry
Tags (3)
kg76
This problem has been solved in the latest release of Trimble Positions Desktop Add-in (10.1.0.2).
It is now possible to check-out from and check-in to a geodatabase and map document located in a network location.
The release notes state:
Trimble Positions Desktop add-in may fail to make a backup copy of an AXF file if the backup folder is located on a network drive. If this situation occurs, a record is added to the log file but the user is not notified.
