Can I Open and edit a point shape file from another point shape file
990
09-30-2013 08:27 AM
AaronMiller3
My question is, If out in the field gathering points in one shape file with its own attribute table is it possible to create a form that will allow you to gather a point with a different attribute table
ex.. If I am gathering points on a pipeline which has its own attributes and I come across a valve which has its own attributes can I open the valve layer for editing from the Pipeline layer? I have eleven different shape files but they are all associated with pipeline
Tags (3)
MatthewPayne
Aaron,
Are you looking to "start editing" on an existing valve layer or do you want to actually create the value layer?  Also, what do you mean by "...can I open the valve layer for editing from the Pipeline layer..."?
Matt
