AXF Layer won't load from Storage Card
2622
02-28-2013 12:50 PM
ChrisSeabrooke
I???m using ArcPad 10.0.4 and I???ve tested on two devices: Trimble Juno 3B and Archer Field PC.
I???m working with a map that has shapefile and AXF layers that are copied to a Storage Card. The shapefile layers load in ArcPad, but not  the AXF layer. I tried loading the layer from Standard ArcPad, but I get a red circle with a slash.
In the Forums, I found this posting that indicated that icon could be caused by SQLCE not being installed correctly.
http://forums.arcgis.com/threads/12263-unable-to-select-.axf-files-in-arcPAD-using-GPS-unit
I hard reset the devices and used Arcpad Deployment Manager to install Microsoft SqlServer 2005 Compact Edition. I still can???t load the AXF file from the storage card.
I moved the AXF file to the MyDocuments folder -- and then I could load it. Why won???t the AXF layer load from the Storage Card?
Any help is appreciated.
Chris
Tags (3)
ChrisSeabrooke
Discovered the AXF file was set to 'read only'. Changed that property and the layer loads.
ChrisSeabrooke
