auto update of shape area
693
05-20-2010 04:13 PM
ChangLiu
Hi all
I'm trying to create a layer definition for a shapefile. when a new shape is created and the editform opens, iwant the area to be automatically placed into an edit control.
i have put the following scripts into the OnLoad event, but when i run arcpad to test the code i get the following error message: "Microsoft VBScript compilation error, Syntax error, [line 1 column 1] Source Text Unavaliable"
what can i do to make it running... tks!!!
Sub UpdateChgCode(pCode)
'Set the value of the last field to pCode
  If Map.SelectionLayer Is Nothing Then
    Exit Sub
  End If
  Dim pRS
  Set pRS = Map.SelectionLayer.Records
  pRS.Bookmark = Map.SelectionBookmark
  pRS.Fields(pRS.Fields.Count).Value = pCode
  'Get the polygons area
  Dim pPoly
  Set pPoly = pRs.Fields.Shape
  pRs.Fields("Shape_area").Value = pPoly.Area
  'Get the edit control and set its value to the area of the new polygon
  Dim pAreaControl, pAreaValue
  Set pAreaControl = Layers("Historic Foundation").Forms("EditForm").Pages("attributePage").Controls("txtSHAPE_Area")
  pAreaControl.Value = pPoly.Area
  pRS.Update
  Set pRS = Nothing
End Sub
Tags (3)
