ArcPad with Barcode Scanner
7282
14
06-15-2011 10:48 AM
BradKiep
Hello all,
I need to collect barcode data while completing a field survey with a Trimble GeoXH.  What are the steps to get the data from the barcode scanner and into a text attribute?  I have seen some posts that say it takes some customization, but no specifics.
My ideal setup would be to have a bluetooth connection to a barcode scanner. Then, when you perform a scan it populates text where the cursor is currently positioned in ArcPad. The entire contents of the barcode can be put in one field, I just want to capture it.
Any help is greatly appreciated!
Thanks for the help,
Brad
Tags (3)
Jakemoon
I know a good barcode solution site. Here share it with you all. I hope it would be helpful for someone. It's called onbarcode. You can rich barcode generators and barcode readers there, like barcode reader for iPhone, barcode reader for Java, Java Class barcode generator library, and C# ASP.NET barcode generator library, etc. I believe you guys can find your barcode solutions there. I have been using the tools from this site for years.
mariahlewis
i'm sure they are talking about barcode scanner app, but i think the resource you offed should include barcode reader,right? not know java barcode recognition can help ?
fdsffdsf
thank you or all the sharing up here. all i need is a .net barcode scanner component, of course , asp.net barcode scanner would be better. i am now very familiar with C# and VB.NET. so any suggestion on how to create this barcode scanner with these two language. i want to make my own, thank you.
mariahlewis
many barcode readers support C#,vb.net and other pro
ArlenMathuis
