ArcPad 8 and .SDC Extension Question
1127
10-12-2010 08:12 AM
StephenZlato
Does anyone know if output files (extension .SDC) generated from the Create Mobile Basemap tool under Mobile Tools in ArcToolbox are designed to work in ArcPad 8?  Thanks!
Tags (3)
fadhilsiddek
yup, sdc can be use in arcpad 8.  just open the . navmap file in arcpad. all the sdc file header are in this navmap. i've create a program which allows to manage all the sdc files in navmap. with this program you can add or remove sdc file from the navmap list, change color, thickness or set the map scale and many features that you can use.
