Arcpad 8.0 crash on GeoXH
1468
01-31-2011 09:30 AM
EricJohnson
We are trying to deploy an aerial photo of our small district to our Trimble GeoXH to have a reference when we're out collecting data. I have been able to create the map as a layer, add the layers I want to edit and check it out for use in the portable unit. We can start the map up on the Trimble, but when we try to use it (center on GPS location, collect a point, etc.) Arcpad crashes to desktop (if that's the appropriate term) and gives the "serious error, do you wish to report it" error message. When I run Arcpad 8.0 on my desktop with this project, this does not occur. I am a bit lost as to my next step.
Eric
Tags (3)
DarrellKelso
Try changing the aerial photo's properties....color schemes, quality, etc..
Make sure you do not have the photo's layer as an editable layer.
EricJohnson
Thanks, I don't have it as an editable layer, and am not sure how to alter the image properties.
Eric
RyanAnderson
If you can work without the imagery, that is your best bet.
