Hi:
I'm having a problem checking data into a File GDB using ArcGIS 10 ArcPad Data Manager. I have point, line, and polygon feature classes in the same file geodatabase that I move to a mobile device using the 'Get Data For ArcPad' option with the ArcPad Data Manager. It doesn't matter whether I export data as editable shp files, an editable axf file, or through Check Out - I get an error about missing a time stamp when I try to move the data back in. I'm not running in a versioned environment, just one PC with data in a file geodatabase. Help!
Cheers,
Will
