ArcMap 10.1 and ArcPad 10
6478
8
03-01-2013 08:38 AM
ColleenLemasters
This is going to sound like a very silly question, and I apologize in advance.
I just started a project where we had intended the work flow to involve checking data in and out of a geodatabase and using ArcPad on our GeoXH's, and I just read the following in the ArcPad 10 help:
At the time of the ArcPad installation, if you have ArcGIS 9.3, the ArcPad 8.0 Data Manager will automatically be installed. If you have ArcGIS 10, the ArcPad 10.0 Data Manager will automatically be installed.
The ArcPad 10.0 Data Manager is only compatible with ArcGIS 10.
I'm having a hard time figuring out how to do this process since the ArcPad Data Manager is apparently not compatible with 10.1. Any help or ideas are greatly appreciated! Once again, I apologize for posting such a silly questions. I just assumed such a useful tool wouldn't just disappear!
Tags (3)
PaulStephenson
ArcPad Data Manger does work with 10.1
I would guess that statement you quoted was a backward compatibility issue.
Good Luck!
Paul
ColleenLemasters
Like I said, a silly question.
Do you know where the toolbar is located in 10.1? I can't seem to find it. I don't recall having trouble finding the toolbar in previous versions.
PaulStephenson
Make sure the extension is enabled, then add the toolbar, both are named ArcPad Data Manager.
Paul
ColleenLemasters
That's how I have done it in the past, but I don't seem to have an extension by that name in the window, or a toolbar named that in the toolbar list. [ATTACH=CONFIG]22318[/ATTACH]
PaulStephenson
You're looking in the right place. However if it's not on the list then it is not currently available (not currently installed on your machine).
Paul
LucasBannan2
Hello clemasters.
pts3 is right that this issue may simply be caused by the ArcPad software not being installed on the machine you are working with. However, if ArcPad is installed on your machine and you are still not seeing the extension or toolbar, the issue you are running into may be that the ArcPadToolsGen2.dll file did not register properly during the installation of ArcPad and ArcGIS (for example ArcPad was installed before ArcMap). In attempt to fix this, you can find the steps to properly register the .dll from the following KB article; ArcPad Data Manager extension is not visible in ArcMap 10.
Hope this helps.
ColleenLemasters
Thank you Luke!!!! I haven't had to use ArcPad since I got my new computer, and I didn't realize ArcPad hadn't been installed on this machine. That was the issue!
JoshZeeb1
Colleen,
Were there any changes in the command prompt that you had to make in order to make the process work? I am running into the same issues as you were.
Thanks
Josh
