"Get data from ArcPad" creates multiple identical records
5419
11
04-25-2011 12:50 PM
MatthewGibbons
The situation:
I am using a file geodatabase to manage all weed mapping data at my office. It is being used by multiple staff members to collect weed data -  and was exported as an axf file ( so multiple users, multiple GPSs).
The problem:
After a day of data collection ??? I upload the data using the ???get data from ArcPad??? function ??? which works great ??? uploads all the data on the GPS to the GDB. BUT, when you collect more data on that GPS the next day ??? and try to upload again ??? it uploads all the records from the previous day again, creating multiple identical records.  There does not seem to be away around this besides deleting all the records from that axf file on the GPS after each day ??? which is far from ideal. There does not seem to be a way of just uploading a subset of the data ??? ie - just that day???s records.
How it worked before:
In 9.3, I exported the GDB to the GPS units as a shapefile to collect the data.  Then, I used the Data Loader function in ArcCatalog to upload the data to the GDB ??? which allows you to setup a query to just upload a specific subset of the data.  This worked great.  Unfortunately, now, when I export the GDB in v10 as a shapefile for the GPS ??? none of the domain dropdowns appear, making it useless for GPS data collection. So, I switched to the AXF file format ??? which allowed the domain dropdowns to appear.  Unfortunately, the ArcCatalog data loader does not recognize axf files ??? so I cannot use this function any longer.  So, now I use the ArcPad Data Manager extension ??? ???get data from ArcPad??? button ??? which does not allow you to query the data  - and just uploads everything in that axf file ??? thereby creating identical records in the GDB.
Any thoughts?  It seems like there should be an easy solution here. Either figure out how to have functional shapefile data collection so I can continue to use the data loader, or figure out how to eliminate identical record uploads from the axf....
Tags (3)
DeniseKing
Matt,
I have logged the inability to re-use forms, scripts etc associated with shapefile during ArcPad copyout process as  CQ00312821; Layer Definition Template checkbox is no longer enabled for shapefiles within Get Data For ArcPad wizard.
You can track this and other CQs through Esri's Customer Care site via My Support > Support Bugs link.
Thank you for bringing this issue to our attention.
Denise
ChrisCarlson
I'm dealing with this problem as well.  I need to use shapefiles for ArcPad as the GPS unit I'm setting up cannot handle the AXF file that is created with lots of domains etc, although it is an empty database.  Anyways, when I'm exporting these geodatabase FC's out to shapefiles for editing using ArcPad Data Manager the "use existing forms/scripts" is not available.  So when this ArcPad project is opened the drop down boxes are there, but they are empty, so field staff are not able to type in them either, and I could certainly fix that, but I really need to have domains for QC.  Is there a way to create these scripts for shapefiles from domains in geodatabases in application builder?  Any insight into getting this functionality back for shapefiles in ArcPad would be greatly appreciated.
