ADDING A STATIC IMAGE TO A FORM IN ARCPAD STUDIO
2603
06-08-2010 03:06 PM
LoriArnold
I am in ArcPad Studio using the Form Wizard to create an Edit Form.  I want a static picture on my form, so I added an ImageControl box.  Under the VALUES tab in CONTROL PROPERTIES I have navigatied to the location of the jpg, though when I go to test the Form in ArcPad, the image does not show up.  If anyone has any ideas as to why, would be muchly appreciated.
Cheers, Lori
Tags (3)
GarethWalters
Hi Lori,
I don't know if you have seen this article from the ArcPad team, but here is an example of how you can add an image to your form.
http://arcpadteam.blogspot.com/2009/07/arcpad-login-form.html
http://arcscripts.esri.com/details.asp?dbid=16477
Good luck with your customising. Let us know how you get on.
Cheers,
Gareth
