Workspace is not connected - DefaultScratchWorkspace
4493
07-19-2010 01:41 PM
DougMarquardt
I am trying to create a standalone featureclass (as per the code example in the ArcObjects 10 help) and I get the subject error when I try and do so.
I open the workspace with this code:
Public Function GetDefaultScratchWorkspaceFactory() As IWorkspace
        Dim ft As Type = Type.GetTypeFromProgID("esriDataSourcesGDB.FileGDBScratchWorkspaceFactory")
        Dim swf As IScratchWorkspaceFactory = CType(Activator.CreateInstance(ft), IScratchWorkspaceFactory)
        Dim wksp As IWorkspace = swf.DefaultScratchWorkspace
        Return wksp
    End Function
Then I try and create the featureclass using this code:
Public Function CreateStandaloneFeatureClass(ByVal workspace As IWorkspace, ByVal featureClassName As String, ByVal fieldsCollection As IFields, ByVal shapeFieldName As String) As IFeatureClass
        Dim featureWorkspace As IFeatureWorkspace = CType(workspace, IFeatureWorkspace)
        Dim fcDesc As IFeatureClassDescription = New FeatureClassDescriptionClass()
        Dim ocDesc As IObjectClassDescription = CType(fcDesc, IObjectClassDescription)
        Dim featureClass As IFeatureClass = featureWorkspace.CreateFeatureClass(featureClassName, fieldsCollection, ocDesc.InstanceCLSID, ocDesc.ClassExtensionCLSID, esriFeatureType.esriFTSimple, shapeFieldName, "")
        Return featureClass
    End Function
I get the error on this line of code:
Should I be able to do this with the default scratch workspace?
Doug.
DougMarquardt
Finally figured out the issue - the error was very misleading.
The problem was with my feature class name - I had spaces in the name.  Removed the spaces and the error went away - DOH!
Cheers!
Doug.
AshleyAbraham
Cheers!
Doug.
Thank you for taking time to post back and saving others, kudos!
