Why does this message appear using a IQueryDef
2944
11-24-2014 07:33 PM
Cristian_Galindo
I am using ArcObjects 10.2, I'm trying to join two tables that I have in a filegeodatabase.
This is my code:
// Arrange
            var path = @"c:\MY_FGDB.gdb";
            var gdbConnector = new GeoDBConnector();
            IWorkspaceFactory workspaceFactory = new FileGDBWorkspaceFactoryClass();
            var ws = workspaceFactory.OpenFromFile(path, 0);
            // Act
            var tableOfRoutes = gdbConnector.OpenTable(ws as IWorkspace2, "Table1");
            var tableWithFeatures = gdbConnector.OpenTable(ws as IWorkspace2, "Table2");
            // Create the query definition.
            IQueryDef queryDef = (ws as IFeatureWorkspace).CreateQueryDef();
            queryDef.Tables = "Table1, Table2";
            queryDef.SubFields = "*";
            queryDef.WhereClause = "Table1.EventID = Table2.Inspection";
            // Make the new TableQueryName.
            IQueryName2 queryName2 = (IQueryName2)new TableQueryNameClass();
            queryName2.QueryDef = queryDef;
            queryName2.PrimaryKey = "Table1.EventID";
            queryName2.CopyLocally = true;
            // Set the workspace and name of the new QueryTable.
            IDatasetName datasetName = (IDatasetName)queryName2;
            datasetName.WorkspaceName = ws as IWorkspaceName;
            datasetName.Name = "inspectionData";
            // Open and return the table.
            IName name = (IName)queryName2;
            ITable InspectionTable = (ITable)name.Open();
At line 31, I get the following exception:
The data necessary to complete this operation is not yet available. (Exception from HRESULT: 0x8000000A)
What I am missing?
Cristian_Galindo
OK, I just figured that in the line 26, I was setting the workspace name in the wrong way, the correct way is:
datasetName.WorkspaceName = (ws as IDataset).FullName as IWorkspaceName;
but now, there is the following exception:
"Value does not fall within the expected range."........but Which value? what does it mean?
Cristian_Galindo
Cristian_Galindo
My mistake, I was setting wrong the primary key
