Why can't I use pRow.set_Value???
849
01-24-2011 09:39 AM
JoshV
Hello All-
I'm creating a C# Standalone application and I have initialized ArcObjects.  Whenever I need to update or add records to a featureclass or table I'm getting an error at pRow.set_Value below stating "Object does not contain a definition for 'set_Value'"...  Now in Visual Studio when I'm writing the code pRow does have set_Value when I type a "." after it.  I'm so confused here..
pRow.set_Value((int)l_FCWellID, pRow.get_Value((int)l_WellID));
Please add any thoughts if you have any.  Many thanks
JoshV
It was my fault.  Datatypes weren't the same..  Sorry
EzequiasRodrigues_da_Rocha
I have the same problem and the value was proper set.
In my case it is in a shapefile.
Any suggestion?
