Why are my parameters considered Invalid Geometry???
753
12-13-2013 09:52 AM
MichaelEber
I have a tool which can also be used at the server.  It currently has two inputs and one output.  The two inputs are defined to use the Standard_Point schema we have defined in our dataset.  I added two new parameters which I added as optional input:
Blockage_Schema which is defined as just a polygon feature.  The other one is Delay_Schema which is a polygon with an additional 2 fields added to the schema definition.
The parameter definitions are as follows:
            get
                IArray parameters = new ArrayClass();
                // origin point for all calls
                IGPParameterEdit3 inputPoint =
                    GPUtilities.CreatePointRecordsetParameterEdit("StationPoint", "Station Point", "Standard_Point",
                        esriGPParameterDirection.esriGPParameterDirectionInput,
                        esriGPParameterType.esriGPParameterTypeRequired, new GPFeatureRecordSetLayerTypeClass(), true);
                parameters.Add(inputPoint);
                // target point array
                IGPParameterEdit3 targetPoints =
                    GPUtilities.CreatePointRecordsetParameterEdit("TargetList", "Target List", "Standard_Point",
                parameters.Add(targetPoints);
                // blockages
                IGPParameterEdit3 inputBlocks = GPUtilities.CreatePointRecordsetParameterEdit("InputBlocks",
                    "Input Blocks", "Blockage_Schema", esriGPParameterDirection.esriGPParameterDirectionInput,
                    esriGPParameterType.esriGPParameterTypeOptional, new GPFeatureRecordSetLayerTypeClass(), true);
                parameters.Add(inputBlocks);
                // delays
                IGPParameterEdit3 inputDelays = GPUtilities.CreatePointRecordsetParameterEdit("InputDelays",
                    "Input Delays", "Delay_Schema", esriGPParameterDirection.esriGPParameterDirectionInput,
                parameters.Add(inputDelays);
                IGPParameterEdit3 outputPoints =
                    GPUtilities.CreatePolylineRecordsetParameterEdit("OutputList", "Output List", "Distance_Schema",
                        esriGPParameterDirection.esriGPParameterDirectionOutput,
                        esriGPParameterType.esriGPParameterTypeDerived, new GPFeatureRecordSetLayerTypeClass(), true);
                parameters.Add(outputPoints);
                return parameters;
When I run the tool I get this error for the optional fields:
[ATTACH=CONFIG]29866[/ATTACH]
When I track down the error it states that the input is an invalid geometry and only points, polylines, and polygons are allowed.
WHY?
