What kind of edit?
4036
07-16-2015 09:33 AM
FabianoFerrazza
Hi All,
do you now a way to determine what kind of edits are made on a feature?
So, by the "OnUpdate" event handler is easy manage a generic edit event on a feature, but seems no possible to now if the edit concern the geometry or an attribute (and, obiouvsly, WHICH attribute).
Could you help me?
Thanks
Fabiano
Tags (1)
JeffMatson
You can use IRowChanges and IFeatureChanges, just QI to an existing IFeature object.
JeffMatson
FreddieGibson
Honored Contributor
I agree with Jeff. IRowChanges would reflect when a non-geometry attribute is updated. IFeatureChanges would reflect when there are changes to the geometry. You could utilize these within an Editor Extension.
IRowChanges Interface
http://resources.arcgis.com/en/help/arcobjects-net/componenthelp/index.html#//0025000007vw000000
IFeatureChanges Interface
http://resources.arcgis.com/en/help/arcobjects-net/componenthelp/index.html#//0025000002qp000000
FabianoFerrazza
Thank you so much Jeff! it's what I need.
