What is the code that add field to layer and does an operation?
1021
11-30-2010 02:48 PM
JamalNUMAN
Legendary Contributor
Please, see the attached image that shows my question
When I press the button in the form, I need to add field to the layer ???School??? and to divide the field maths on pupils
What is the code?
Thank you
Jamal Numan
TomGiles
Hi Jamal,
I'm no expert, but I would think this could be done much easier in a python script tool; partly because I have the code in front of me... 🙂
I've removed all the try/excepts, but it would look something like this:
import arcpy
fc = arcpy.GetParameterAsText(0)                                   #this would come from a input box (the only one in the tool)
if len(arcpy.ListFields(fc, "aFieldName")) < 1:                      #check if your new field exists otherwise create it
     arcpy.AddField_management(fc, "aFieldName", "DOUBLE")
rows=arcpy.UpdateCursor(fc)
for row in rows:
     row.aFieldName = row.Math / row.Pupil #whatever calculation you need to do
rows.updateRow(row)
del row
del rows
Now in vb... which I don't have the code for, it would look something like this:
'i dont show var declarations in the first init step here
'load map, layer, etc, my 'm_application' is passed to my form_init function, so I start with getting the map doc from this
pMxDoc = m_application.Document
pMap = pMxDoc.FocusMap
pLayer = pMxDoc.SelectedLayer
'once you have the FC loaded (pFC) you can access fields for selected records by:
Dim pFc = pLayer.FeatureClass
pFC = pLayer.FeatureClass
Dim pFSel As IFeatureSelection
pFSel = pLayer
Dim pSelSet As ISelectionSet
pSelSet = pFSel.SelectionSet
pSelSet.Search(Nothing, False, pFCur)
Now you have a pFCur which is a cursor of all selected features
You can access each by a for loop using pFeat = pFCur.NextFeature (declared as Dim pFeat As IFeatureCursor)
You change individual values by finding the index for a field like this:
Dim aNewFieldIndex As Integer
aNewFieldIndex = pFC.FindField("aNewField")
and change values by the index, like this:
pFeat.Value(aNewFieldIndex) = "1" (or a variable from a calculation from other fields)
Like I said I would use the python option, and you can throw it into a batch grid and drag FCs from ArcCatalogue, without even opening the data.
Cheers,
Tom
