Versioned edit with ArcObjects C#
1938
04-13-2021 10:50 PM
forestknutsen1
Can someone please point me to a good example for using versioned editing with a C#? I am working on a console application to edit attributes in a sde geodatabase.
The below is working for non-versioned tables.
           Console.WriteLine("start editing");
           IWorkspaceEdit workspaceEdit = (IWorkspaceEdit)workspace;
           workspaceEdit.StartEditing(false);
           workspaceEdit.StartEditOperation();
           TestFeature.Value[fieldIndex] = testString;
           TestFeature.Store();
           workspaceEdit.StopEditOperation();
           workspaceEdit.StopEditing(true);
           Console.WriteLine("editing stopped");
Thanks!
Tags (1)
forestknutsen1
No, not yet....
SherryVotava
You'll need to use iVersionedWorkspace and iVersion.  Something like this prior to the code you shared...
pVersionedWorkspace = pWorkspace
pVersion = pVersionedWorkspace.FindVersion("myversion")
'check to make sure pVersion is not nothing
pWorkspace = pVersion
