VB.NET WhereClause table/Field
1697
01-22-2021 05:47 AM
SigurdurGesr
Hi
how can I get data from table/Field  = EXTRA.House   / number
   Public Sub search_address()
        Dim pMap As IMap
        Dim pMxDoc As IMxDocument
        Dim pFeatLayer As IFeatureLayer
        Dim pFeatSel As IFeatureSelection
        Dim pQueryFilter As IQueryFilter
        pMxDoc = CType(My.ArcMap.Application.Document, IMxDocument)
        pMap = pMxDoc.FocusMap
        Dim sLayerName As String
        sLayerName = Layer_address
        Dim i As Integer
        For i = 0 To pMap.LayerCount - 1
            If pMap.Layer(i).Name = sLayerName Then
                pFeatLayer = pMap.Layer(i)
                Exit For
            End If
        Next i
        If pFeatLayer Is Nothing Then
            MsgBox(Layer_address & " Error")
            Exit Sub
        End If
        pQueryFilter = New QueryFilter
        pQueryFilter.WhereClause = "HEI1 in (select HEI1 from EXTRA.House where number = 2502163)"
        Dim pFeaCursor As IFeatureCursor = pFeatLayer.Search(pQueryFilter, False)
        Dim pFeature As IFeature = pFeaCursor.NextFeature
        Do Until pFeature Is Nothing
            Dim index As Integer = pFeature.Fields.FindField("STREETNAMECODE") 'O(n)
            Dim sName As String = pFeature.Value(index)
            Dim newItem As New ListViewItem(pFeature.OID)
                If IsDBNull(pFeature.Value(pFeature.Fields.FindField("POSTALCODE"))) = False Then
                    newItem.SubItems.Add(pFeature.Value(pFeature.Fields.FindField("POSTALCODE")))
                Else
                    newItem.SubItems.Add("")
                End If
                If IsDBNull(pFeature.Value(pFeature.Fields.FindField("STREETNAME"))) = False Then
                    newItem.SubItems.Add(pFeature.Value(pFeature.Fields.FindField("STREETNAME")))
                Else
                End If
                Listv_search.Items.Add(newItem)
            pFeature = pFeaCursor.NextFeature
        Loop
Tags (1)
GKmieliauskas
Here is your problem:
You need to add to WhereClause only where section of your query:
        pQueryFilter.WhereClause = "number = 2502163"
SigurdurGesr
I can get record from pFeatLayer but I can not get record from EXTRA.House
JoshuaBixby
MVP Esteemed Contributor
What is your backend data source, RDBMS, FGDB, etc...?  I assume you are getting an error, what exactly is the error message?
