VB.Net - Selecting only Polyline layers from the TOC
1568
01-23-2018 01:58 PM
JeffreyFrye
I can successfully get all layers in the TOC into a combo box, but I only want to get layers that are of a polyline geometry in the TOC. My apologies, I do not know the proper method for inserting code here.
Protected Overrides Sub OnClick()
        Dim settingsForm As New Settings
        Dim myEnumLayers As ESRI.ArcGIS.Carto.IEnumLayer
        Dim fLayers As ESRI.ArcGIS.Carto.ILayer
        Try
            myEnumLayers = My.ArcMap.Document.FocusMap.Layers
            fLayers = myEnumLayers.Next
            Do Until fLayers Is Nothing
                If fLayers.Valid Then
                    If TypeOf fLayers Is ESRI.ArcGIS.Carto.IFeatureLayer Then
                        settingsForm.ComboBox1.Items.Add(fLayers.Name)
                    End If
                End If
            Loop
        Catch ex As Exception
        End Try
        settingsForm.Show()
  End Sub
JeffreyFrye
Thank you Mody - this got me going in the right direction. Instead of using ILayer, I used IFeatureLayer. I was then able to check each layer to identify IFeatureClass(es), which allowed me to access the geometry and return only polyline types. This class is designed to iterate through the current mxd layers, and populate a combobox with polyline layers only, via an add-in button.
Public Class SelectRoadLayer
  Inherits ESRI.ArcGIS.Desktop.AddIns.Button
  Public Sub New()
  End Sub
        Dim fLayers2 As ESRI.ArcGIS.Carto.IFeatureLayer
        Dim fClass As ESRI.ArcGIS.Geodatabase.IFeatureClass
        Try
            fLayers2 = myEnumLayers.Next
            Do Until fLayers2 Is Nothing
                If fLayers2.Valid Then
                    fClass = fLayers2.FeatureClass
                    If fClass.ShapeType = ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPolyline Then
                        settingsForm.ComboBox1.Items.Add(fLayers2.Name)
                    End If
                End If
            Loop
        End Try
        settingsForm.Show()
  End Sub
  Protected Overrides Sub OnUpdate()
    Enabled = My.ArcMap.Application IsNot Nothing
  End Sub
End Class
ModyBuchbinder
Try if ( fLayers.FeatureClass.ShapeType = esriGeometryType.esriGeometryPolyline)
I am not sure about VB syntex but this is the way.
You can also give parameter to the My.ArcMap.Document.FocusMap.Layers to get only featurelayers.
Have fun
Mody
JeffreyFrye
  Public Sub New()
  End Sub
        Try
                    End If
                End If
            Loop
        End Try
        settingsForm.Show()
  End Sub
  End Sub
End Class
KenBuja
MVP Esteemed Contributor
One thing to be aware of. When you're cycling through the layers of your map, you may have other layers in there that are not feature layers. That would crash your code. You should use this code to make sure it is.
Dim pLayer As ESRI.ArcGIS.Carto.ILayer2
pLayer = pEnumLayers.Next
Do Until pLayer Is Nothing
  If TypeOf pLayer Is ESRI.ArcGIS.Carto.IFeatureLayer Then
    pFLayer = New ESRI.ArcGIS.Carto.FeatureLayer
    pFLayer = pLayer
   ' your additional code
  End If
Loop
