Using QueryBuilder dialog with raster files
1434
05-31-2012 02:43 PM
GaryPoole
I'm using the built in QueryBuilder dialog to design my 'where' clauses with shapefiles. This code works great for me:
                IQueryBuilder queryBuilder = new QueryBuilder();
                String whereClause = String.Empty;
                String fullPath = "C:\\Test\\Shapefile.shp";
                String path = Path.GetDirectoryName(fullPath);
                String filename = Path.GetFileName(fullPath);
                // Set up the Shapefile query
                IWorkspaceFactory workspaceFactory = new ShapefileWorkspaceFactory();
                IWorkspace workspace = workspaceFactory.OpenFromFile(path, 0);
                IFeatureWorkspace featureWorkspace = (IFeatureWorkspace)workspace;
                IFeatureClass featureClass = featureWorkspace.OpenFeatureClass(filename);
                ESRI.ArcGIS.Carto.IFeatureLayer featureLayer = new ESRI.ArcGIS.Carto.FeatureLayer();
                featureLayer.FeatureClass = featureClass as IFeatureClass;
                ESRI.ArcGIS.Carto.ILayer layer = featureLayer;
                queryBuilder.Layer = layer;
                queryBuilder.WhereClause = whereClause;
                queryBuilder.DoModal(SettingsManager.ArcDesktopApplication.hWnd);
Now I'd like to do the same but with using a raster file. After several hours of investigating, I haven't found the magic solution. Any ideas?
Thanks!
GaryPoole
Any ideas anyone? I know this can be done, as it is used with the CON (Input conditional raster) geoprocess. Any help would be greatly appreciated!
GaryPoole
In case anyone is interested, the solution was to implement IQueryPropertyPage
ChaoWang
Here's the detailed info:
(a)create a query property page by using IQueryPropertyPage interface
(b)Put the query property page in a property sheet by using AddPage method of the IComPropertySheet interface
(c)Display the property sheet in the application by using the EditProperties method of IComPropertySheet interface.
Sample codes with which I can open the query builder for rasters on my end successfully, please note the code is for demonstration purposes and please modify if necessary:
        String fullPath = @"C:\temp\testhillshade"; // Please modify the path here
            //IWorkspaceFactory workspaceFactory = new ShapefileWorkspaceFactory();
            //IWorkspace workspace = workspaceFactory.OpenFromFile(path, 0);
            //IFeatureWorkspace featureWorkspace = (IFeatureWorkspace)workspace;
            //IFeatureClass featureClass = featureWorkspace.OpenFeatureClass(filename);
            //Open raster workspacefactory
            IWorkspaceFactory workspaceFactory = new RasterWorkspaceFactory();
            //Raster dataset
            IRasterWorkspace RasterWorkspace = (IRasterWorkspace)workspace;
            IRasterDataset rasterDS = RasterWorkspace.OpenRasterDataset(filename);
            //Raster layer
            ESRI.ArcGIS.Carto.IRasterLayer rasterLayer = new ESRI.ArcGIS.Carto.RasterLayer();
            rasterLayer.CreateFromDataset(rasterDS);
            IQueryPropertyPage pQueryPropertyPage = new QueryPropertyPageClass();
            pQueryPropertyPage.Table = rasterLayer as ITable;
            ISet pSet = new SetClass();
            pSet.Add(rasterLayer);
            IComPropertySheet pSheet = new ComPropertySheetClass();
            pSheet.AddCategoryID(new UID());
            pSheet.AddPage(pQueryPropertyPage);
            pSheet.Title = "query";
            if (pSheet.EditProperties(pSet, ArcMap.Application.hWnd))
Here are also documents talking about the  property page:
Extending ArcObjects:Creating Property Pages
http://edndoc.esri.com/arcobjects/9.2/CPP_VB6_VBA_VCPP_Doc/COM/ExtendAO/PropertyPages.htm#Implementi...
How to open a layer's property pages using VBA in ArcMap
http://resources.arcgis.com/content/kbase?fa=articleShow&d=17082
Hope this helps,
Chelsea
