Using Bentley.Interop.MicroStationDGN.dll and Bentley Microstation DGN Object Library
2785
10-10-2012 11:51 PM
TaiBui
Can I use Bentley.Interop.MicroStationDGN.dll instead of using COM interface MicroStationDgn ( Bentley Microstation DGN Object Library) ?
My application  is using COM interface MicroStationDgn for reading Dgn files. It requires MicroStation V8i must be installed on my computer.
I want still can run my application without installing Microstation V8i. But, there are some differences between Bentley.Interop.MicroStationDGN.dll and Bentley Microstation DGN Object Library
For example: Bentley.Interop.MicroStationDGN.ApplicationClass doesn't include the methode OpenDesignFile
Thanks and regards,
Tai
KarenHodge
You'll probably want to check with the Bentley folks on this.
