Using ArcObjects to Append Text to Time Display in ArcMap
1597
07-19-2016 10:28 AM
ThomasCox
I am looking for a way through ArcObjects to display additional text on the Time Display that appears on the map for time based data.
In native ArcMap , I am able to navigate the Time Slider Options window and open the Time Text Appearance dialog. I can add text manually that will appear.  However, I have not been able through ArcObjects to programatically achieve this.  I have been working with IMapTimeDisplay2 but have not had any luck.  This interface seems to only have methods addressing time format.  Any suggestions would be appreciated
I have attached a jpg that is a screen shot of what I described doing above in native ArcMap.  I appended the words additional text to the display on the map.  I need to be able to do this programatically.
Thanks
