Trouble looping through a selection set where feature type is polyline which is part of a topology class.
1264
08-31-2017 05:26 AM
LawrenceHartpence
Hello.
I have code that loops through selected features and updates an attribute for those features.  The code throws an error at runtime when the featureclass is a polyline type which participates in a topology class.  The error seems to happen at iSelectionset.Update.  Below is the entire function.  Any ideas would be appreciated.
Private Sub txtRFrom_KeyPress(sender As Object, e As KeyPressEventArgs) Handles txtRFrom.KeyPress
If Asc(e.KeyChar) = 13 Or Asc(e.KeyChar) = 9 Then
If cmbLayer.SelectedIndex = -1 Then
MsgBox("Please Select an Edit Layer!!")
Exit Sub
End If
Dim intValue As Integer
If Not Integer.TryParse(txtRFrom.Text, intValue) Then
txtRTo.Focus()
Exit Sub
End If
Dim pfLayer As IFeatureLayer
pfLayer = FindLayerByName(cmbLayer.SelectedItem)
Dim pfClass As IFeatureClass
pfClass = pfLayer.FeatureClass
Dim pfeatsel As IFeatureSelection
pfeatsel = pfLayer
Dim pSelectionSet As ISelectionSet2
pSelectionSet = pfeatsel.SelectionSet
If pSelectionSet.Count = 0 Then
MsgBox("No features selected!!")
Exit Sub
End If
Dim pFeatureCursor As IFeatureCursor
pFeatureCursor = Nothing
Dim pFeature As IFeature
'update the selectionset setting the IQueryFilter object to Nothing
pSelectionSet.Update(Nothing, False, pFeatureCursor)
pFeature = pFeatureCursor.NextFeature
Do Until pFeature Is Nothing
pFeature.Value(pFeature.Fields.FindField("RFromAddr")) = txtRFrom.Text
pFeatureCursor.UpdateFeature(pFeature)
txtRTo.Focus()
Loop
End If
End Sub
DuncanHornby
MVP Notable Contributor
If you want people to help I suggest you edit your question and ensure formatting of code is on as it makes it easier to read. Have a look here if you do not know how to do this.
If you read the API help for the Update method, it states at the bottom:
All edits to features that participate in a Topology or Geometric Network must be bracketed within an edit operation.
Your code does not indicate if an Edit operation has been started so I'm guessing that is the issue.
