The memory leak of ArcGIS ?
753
07-20-2010 03:55 AM
huangJary
This is my code,  VC 6.0++,   the leak detector is Rational Purify,
if (!InitializeApp())
  AoExit(0);
IWorkspaceFactoryPtr ipWorkspaceFactory;
ipWorkspaceFactory.CreateInstance(CLSID_FileGDBWorkspaceFactory);
if (ipWorkspaceFactory == NULL)
  return;
IWorkspacePtr ipWorkspace;
HRESULT hr;
hr = ipWorkspaceFactory->OpenFromFile((CComBSTR)"E:\\TestData\\testdata\\Latest.gdb", 0, &ipWorkspace);
The result is:
    MPK: Potential memory leak of 32 bytes from 2 blocks allocated in String::String(WORD const*,DWORD) [AFCORE.DLL]
    Offset 0x00000008 referenced by 0x0a06f4a4, a location in a section in a loaded module
Distribution of potentially leaked blocks
            32 bytes from 2 blocks of 16 bytes (first block: 0x09a22360)
Allocation location
            new(UINT)
MLK: Memory leak of 1 byte from 1 block allocated in wsetlocale [MSVCR71.DLL]
Distribution of leaked blocks
                 1 byte from 1 block of 1 byte (0x099a5e08)
Allocation location
            malloc
            wsetlocale
nazerehnejatbakhsh
Hey all,
I tried your codes to open a File GDB Workspace which already exists with the name testGDB.gdb:
there is also a sample in EDN, I have ArcGIS 10, Visualstudio 2008.
I always get NULL result for the variable "outWorkspace", that is why I cant get any pointer to create a feature class inside the GDB.
Is there something I am missing !? any hint !????
I have checked several times, there is no problem with my path ! because the testGDB.gdb is created directly by ArcGIS
connString is in my case : C:\Daten\Bearbeitung\testGDB.gdb which goes with the codes.
http://resources.esri.com/help/9.3/arcgisdesktop/com/samples/Geodatabase/Accessing_Data/07EA5491-885...
HRESULT openFGDBWorkspace(BSTR connString, IWorkspace** outWorkspace)
      IWorkspaceFactoryPtr ipWorkspaceFactory(CLSID_FileGDBWorkspaceFactory);
      return ipWorkspaceFactory->OpenFromFile(connString, NULL, outWorkspace);
