Summarize a field grouped  by values in the field
875
05-08-2014 06:20 AM
RichardMoussopo
Hi all,
I am trying to summarize a field and populate the result in a listview. below is the code of what I am trying to accomplish but with no success. I want it to work as the summarize tool in ArcMap when right clicking the Field to summarize. I am wondering if there is a Select COUNT(fieldName) Group By (fieldName).
Private Sub btnCheckData_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnCheckData.Click
        'Load result in the listbox
        Dim selectedFieldName As String = Nothing
        If cboBoxFields.SelectedIndex <> -1 Then
            ListViewDataresult.Enabled = True
            selectedFieldName = cboBoxFields.SelectedItem.ToString
            ListViewDataresult.Items.Clear()
            ListViewDataresult.BeginUpdate()
            Dim newlist As ListViewItem
            Try
                'check if we have the fieldName
                If selectedFieldName = Nothing Then
                    Exit Sub
                End If
                Dim flayerName As String = cboBoxLayers.SelectedItem.ToString
                Dim mxDoc As IMxDocument = My.ArcMap.Application.Document
                Dim map As IMap = mxDoc.FocusMap
                Dim enumLayer As IEnumLayer = map.Layers
                Dim layer As ILayer = enumLayer.Next()
                Dim flayer As IFeatureLayer = Nothing
                Do While Not layer Is Nothing
                    If layer.Name = flayerName Then
                        flayer = CType(layer, IFeatureLayer)
                    End If
                    layer = enumLayer.Next()
                Loop
                If flayer Is Nothing Then
                    MessageBox.Show("No layer")
                    Exit Sub
                End If
                Dim fclass As IFeatureClass = flayer.FeatureClass
                'define the cursor to store data
                Dim pCursor As ESRI.ArcGIS.Geodatabase.ICursor
                'define datastat to query unique values
                Dim pDataStats As New ESRI.ArcGIS.Geodatabase.DataStatistics
                'define data collection
                Dim pEnum As System.Collections.IEnumerator
                pCursor = fclass.Search(Nothing, False)
                pDataStats.Field = selectedFieldName
                pDataStats.Cursor = pCursor
                pEnum = pDataStats.UniqueValues
                Dim dataStatResult As IStatisticsResults = pDataStats.Statistics
                pEnum.Reset()
                Do While pEnum.MoveNext
                    'This part works fine. it will add unique attributes in the listview in the 1st column
                    newlist = ListViewDataresult.Items.Add(pEnum.Current)
                    ' I wish to have here a number of  values that have the same attribute like the summarize in ArcMap, but instead it gives me the total of unique values in the current pDataStats
                  'here is where I want to add the count of duplicate attributes in the 2nd column
                    newlist.SubItems.Add(pDataStats.UniqueValueCount)
                Loop
                ListViewDataresult.EndUpdate()
                ListViewDataresult.Refresh()
                'MessageBox.Show(statResut.Count.ToString)
            Catch ex As Exception
                MessageBox.Show(ex.Message)
            End Try
        End If
    End Sub
