SQL syntax in query filter interface
1653
04-25-2010 03:03 AM
RadekHýbner
Hi
I am writing some tool in ArcGIS desktop 9.3 in VBA and I need to extract data in table by query filter interface.
I have data in personal db and
pQf.WhereClause = "TextString <> Null"
is OK. But when I have data in File db theres a problem. I know that there is syntax a little different... but I can not find correct version.
Thanks.
StefanOffermann
For File Geodatabase, you have to enquote field names with double quotes:
"Field" = 'Value'
see: http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?TopicName=SQL_reference
regards, Stefan
RadekHýbner
thanks for reply.
but I tried this before and it writes me that it is not correct...
StefanOffermann
Then you have an error in your code. The double quotes are the right way. I don't know the exact way in VBA to escape the double quotes, in C# I would write:
pQf.WhereClause = "\"FieldName\" <> Null"
You should check how to use
and
Null
in VBA.
JohnHauck
You can use the following for either File or Personal geodatabase:
pQF.WhereClause = "YourFieldName IS NOT NULL"
RadekHýbner
correct is
thanks
