Setting Tolerance in ArcEngine10 Edit mode
649
06-17-2013 03:58 AM
HowardNaulty
I have an application on a touch enabled device in which I'm using ArcEngine 10 to run the map control. I'm using the toolbar control to start the engine editor to edit map features. When I start the editor, I notice that the tolerance is this tiny dot and the features on the map are very difficult to select and move using a finger.
My question is, how do I increase the tolerance level on the features on the map during that edit session? Is that controlled in the MXD, or is it some code that I need to add to the initialization of the map control? Any assistance on this would be greatly appreciated.
Howard
